It is currently Tue Aug 05, 2025 5:51 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Mon Oct 15, 2018 7:46 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
I misunderstood what was slipping in this post at the beginning. I thought you were talking about the router jig not the collar and bit.
Sent from my SM-G935V using Tapatalk
Hutch
PostPosted: Mon Oct 15, 2018 8:59 pm
I believe it’s the bit now that some have brought it up
PostPosted: Thu Oct 18, 2018 6:32 am
Well I awoke this morning with finishing on the brain. This guitar is coming up being very “honest” looking. Not a lot of frills, but the simple natural beauty is there.
One guitar I have , a Halcyon, is a semi gloss finish with open pores. It kind of has that same vibe, so I’m considering a similar finish. I may actually do Tru-Oil on this one, although I’ve only done one previously with TO.
(Any threads out there for TO?)
I’ll echo that question in another thread since it’s a different topic.
PostPosted: Sat Oct 20, 2018 9:15 am
Doing a little flossing to get the neck to center left to right. I’m a full 16th off center at this point:/ but I should be able to coax it.. also a hump in the neck around the headstock but I can sand that down :) going nicely overall ImageImage
And yea it’s time to
Clean the shop room:)
PostPosted: Fri Oct 26, 2018 6:37 am
I’m in the final sanding stages before locating stuff and doing some taping for finish.
I’m in the process of smoothing the edge off of the binding so it doesn’t feel sharp against you.
When you guys do this do you simply round it over w sand paper and donit by eye? How do you get it exactly uniform? Or do you?
Btw.... if you’re new and reading this... remember to keep the binding 90degrees at the fingerboard / body joint:) don’t ask how I know
PostPosted: Fri Oct 26, 2018 7:11 am
I sand it by eye in two stages. I use a small wooden block about 1/2" x 1" with p320 and do a 45 degree bevel all the way around. The bevel not very wide, 1/32 or less. It's easy to keep the bevel at a relatively constant width. Then I follow up with p320 on a rubber block about the same size to finish the roundover. Don't forget to leave the binding square under the fretboard.
These users thanked the author SteveSmith for the post: SnowManSnow (Fri Oct 26, 2018 9:11 am)
 Post subject: Build number ... hmmm 9?
PostPosted: Sat Oct 27, 2018 3:47 pm
First very thin coat of TruOil.
The finish isn’t this dark. The wood is cooked thus the darker look
PostPosted: Tue Oct 30, 2018 5:16 pm
Just done with the first light “level scuff” and then a further thinner coat of TO
I only have 6 coats total so far.
I’m a little surprised at how red this is turning.
Maybe it is a reaction w the toro ford wood some how ? For comparison here is torified wood from the same supplier finished w em6000
PostPosted: Fri Nov 02, 2018 2:24 pm
PostPosted: Fri Nov 02, 2018 3:19 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That is looking great!
Bryan Bear PMoMC
PostPosted: Fri Nov 02, 2018 4:48 pm
Tops give me fits!
I’ve yet to get a good slick even finish.
Getting better every build though:)
PostPosted: Fri Nov 02, 2018 6:02 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Getting better each time is all you can ask for. I hope for each new build to make me ashamed of the previous one in some way.
Bryan Bear PMoMC
PostPosted: Fri Nov 02, 2018 7:20 pm
Right on.
It has been a great few years for me doing this. Been loving it (mostly):)
Users browsing this forum: dofthesea and 10 guests
